I updated my Lexicon but I see here some changes!!!
Beitragvon mariocaz » 13. Sep 2005 18:27
Hello Amigalink!!!
I updated my Lexicon but I see here some changes in the code of some files but everything that you explain is in German jajaja so I can't understand anything. :cry:
http://www.amigalink.de/viewtopic.php?t=204
So I only have to do the update that is the file of the Lexicon 2.04 or I have to do something else ??? :?
Another thing I installed the Quicklinks for the Lexicon but it doesn't works :cry: , I don't know why ?? Is that because I have the CH MOD in my 1.52 phpbb2 Plus ? or anthother reason ? :idea:
Regards my friend and thanx !! :)
Mario
Added after 3 minutes:
Off Topic jeje I put here this link:
And I see that is converted automatically like this:
Where can I find this great MOD ? :P
mariocaz
Beitragvon AmigaLink » 14. Sep 2005 02:14
After update to 2.0.4 you must do this 2 fixes:
http://www.amigalink.de/viewtopic.php?t=204#1827
http://www.amigalink.de/viewtopic.php?t=204#1959
The first is only a small stylefix and the second removes a bug in the crosslinks. :)
I have not test the Quicklinks addon on a plus board but there should be no reason that it doesn't work. :shock:
<!-- BEGIN Off_Topic -->
That ist the Raw_URL_Converter with my http://www.amigalink.de/viewtopic.php?t=226 :)
<!-- END Off_Topic -->
Zuletzt geändert von AmigaLink am 14. Sep 2005 21:42, insgesamt 1-mal geändert.
Beitragvon mariocaz » 14. Sep 2005 18:54
Thanx again my friend for everything I did the changes in the lexicon and I did again the Quicklinks MOD for the Lexicon and now works perfectly :D , I think I did something wrong and I corrected this time. :roll:
Regards and thanx a lot ! :wink:
mariocaz
