2 questions about Lexicon
Beitragvon Avid » 29. Apr 2006 15:42
Hello !
1 > Since I added the code to lock Lexicon (see topic here), everything works fine but the default title, named "Général" in the lang_main.php became blank in the pop-up menu...cosmetic problem, only...
2 > I'd like the categories titles by alphabetical order. As there's no possibility in the ACP to change it, could you give me any trick?
Thanks again :wink:
Avid
Beitragvon AmigaLink » 29. Apr 2006 19:14
  1. There ist no reason for that problem. You must done a mistake by change other things at your board.
  2. Code: Alles auswählen
    lexicon.php
    // Grab lexicon categories
    $sql = "SELECT cat_id, cat_titel FROM " . LEXICON_CAT_TABLE;
    $sql = "SELECT cat_id, cat_titel FROM " . LEXICON_CAT_TABLE . ' ORDER BY cat_title';
Beitragvon Avid » 29. Apr 2006 19:43
1 > you're right. I've done a mistake.
2> Thank you a lot for the trick (so simple) :oops:
it's okay for the alpha order. But even if I call the default category "x, y, -, bob/whatever" it does'nt take the right place (all the time it's like if it was a "d" in the alphabetical order).
Before the trick you gave me, the default category was at the begining. Now it's in the alpha order like I said. Do you think it would be possible to put it at the end of the list, named like "---" for instance ?
Avid
Beitragvon AmigaLink » 30. Apr 2006 11:21
The assortment will always done by the database given category names. Thus all catogries they have a name out of the language files (like the default cat) sorted wrong. There is no way to change this.
Zuletzt geändert von AmigaLink am 30. Apr 2006 13:02, insgesamt 1-mal geändert.
Beitragvon Avid » 30. Apr 2006 12:51
... okay. It doesn't matter. :)
thanks
Avid
Mitglieder in diesem Forum: 0 Mitglieder und 34 Gäste
