Fehlrmeldung
Fehlrmeldung
Beitragvon Snoopy » 24. Feb 2007 16:04
Das erste was ich geschrieben hatte, hat sich erledigt!
Nun bekomme ich folgende Meldung:
Parse error: parse error, unexpected ')' in J:\XAMPP\xampp\htdocs\Snoopyforum\portal.php on line 54
Die Changecodes von hier sind eingebaut!
Zeile 50-61:
   'automaticSerialization' => $portal_config['md_cache_serialize']
$var_cache = new Cache_Lite($options);
isset($HTTP_GET_VARS['page'])) ? $layout = intval($HTTP_GET_VARS['page']) : $layout = $portal_config['default_portal'];
if($portal_config['cache_enabled'])
   $layout_row=$var_cache->get('lr' . strval($layout), 86400, 'layout');
if(!$layout_row)
Zugefügt nach 1 Stunde(n) 28 Minute(n):
Auch das hat sich geklärt!
Das nächste, wenn ich nun ins ACP möchte bekomme ich folgendes:
Warning: include(./includes/sessions.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 195
Warning: include() [function.include]: Failed opening './includes/sessions.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 195
Warning: include(./includes/auth.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 196
Warning: include() [function.include]: Failed opening './includes/auth.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 196
Warning: include(./includes/functions.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 197
Warning: include() [function.include]: Failed opening './includes/functions.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 197
Warning: include(./includes/db.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 198
Warning: include() [function.include]: Failed opening './includes/db.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 198
Warning: include(./includes/functions_showbot.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 206
Warning: include() [function.include]: Failed opening './includes/functions_showbot.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 206
Fatal error: Call to undefined function encode_ip() in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 218
Zeile 190-220:
   exit;
include($phpbb_root_path . 'includes/constants.'.$phpEx);
include($phpbb_root_path . 'includes/template.'.$phpEx);
include($phpbb_root_path . 'includes/sessions.'.$phpEx);
include($phpbb_root_path . 'includes/auth.'.$phpEx);
include($phpbb_root_path . 'includes/functions.'.$phpEx);
include($phpbb_root_path . 'includes/db.'.$phpEx);
if ( defined('IN_CASHMOD') )
   include($phpbb_root_path . 'includes/functions_cash.'.$phpEx);
// We do not need this any longer, unset for safety purposes
unset($dbpasswd);
include($phpbb_root_path . 'includes/functions_showbot.'.$phpEx);
// Obtain and encode users IP
// I'm removing HTTP_X_FORWARDED_FOR ... this may well cause other problems such as
// private range IP's appearing instead of the guilty routable IP, tough, don't
// even bother complaining ... go scream and shout at the idiots out there who feel
// "clever" is doing harm rather than good ... karma is a great thing ... :)
$client_ip = ( !empty($HTTP_SERVER_VARS['REMOTE_ADDR']) ) ? $HTTP_SERVER_VARS['REMOTE_ADDR'] : ( ( !empty($HTTP_ENV_VARS['REMOTE_ADDR']) ) ? $HTTP_ENV_VARS['REMOTE_ADDR'] :getenv('REMOTE_ADDR') );
$user_ip = encode_ip($client_ip);
// CrackerTracker v5.x
include($phpbb_root_path . 'ctracker/engines/ct_varsetter.' . $phpEx);
Ich hatte eben erst festgestellt, das ich die SQL Anweisung nicht ausgeführt war! Anscheinend hat das das Update auf Dim 3 überschrieben!
Deswegen hatt ich es eben erst ausgeführt!
Könnte es vielleicht daranliegen?
Beitragvon AmigaLink » 24. Feb 2007 20:22
Was hattest du denn geschrieben? :?
Die Fehlermeldung besagt das die sessions.php nicht existiert. :shock:
Das hat nichts mit irgendwelchen SQL Anweisungen zu tun.
Beitragvon khaledelmansoury » 24. Feb 2007 23:53
Wow!
Wie soll denn ein phpBB2 Forum denn ordnungsgemäsig laufen ohne der sessions.php
Er sagt die Meldung kommt wenn er ins ACP geht:
1.Warning: include(./includes/sessions.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 195
2.
3. Warning: include() [function.include]: Failed opening './includes/sessions.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 195
4.
5. Warning: include(./includes/auth.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 196
6.
7. Warning: include() [function.include]: Failed opening './includes/auth.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 196
8.
9. Warning: include(./includes/functions.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 197
10.
11. Warning: include() [function.include]: Failed opening './includes/functions.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 197
12.
13. Warning: include(./includes/db.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 198
14.
15. Warning: include() [function.include]: Failed opening './includes/db.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 198
16.
17. Warning: include(./includes/functions_showbot.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 206
18.
19. Warning: include() [function.include]: Failed opening './includes/functions_showbot.php' for inclusion (include_path='.;J:\XAMPP\xampp\php\pear\') in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 206
20.
21. Fatal error: Call to undefined function encode_ip() in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 218
22.
und noch viele andere dateien existieren nicht wie die db.php ,...
Aber der Pfad ist richtig: ((Warning: include(./includes/sessions.php) [function.include]: failed to open stream: No such file or directory in J:\XAMPP\xampp\htdocs\Snoopyforum\common.php on line 195 )
Oder hat er das Forum geladen, ein paar Dateien gelöscht und das ACP aufgerufen ?
Aber selbst das würde nicht funktionieren... :mrgreen:
khaledelmansoury
Beitragvon AmigaLink » 25. Feb 2007 09:47
Stimmt, das ist vollkommen unlogisch. :x
Beitragvon Snoopy » 25. Feb 2007 12:22
Ich hab nix gelöscht!
Urplötzlich kam diese Meldung!
Da ich eh nicht soweit mit dem Forum war, hab ich noch mal angefangen und nun läuft es!
