Problem with EasyUCP hack
Beitragvon gwuk » 22. Jan 2005 02:44
I got stuck on a bit of this modification:
Find in usercp_register.php:
            SET " . $username_sql . $passwd_sql . "user_email = '" . str_replace("\'", "''", $email) ."', user_icq = '" . str_replace("\'", "''", $icq) . "', user_website = '" . str_replace("\'", "''", $website) . "', user_occ = '" . str_replace("\'", "''", $occupation) . "', user_from = '" . str_replace("\'", "''", $location) . "', user_interests = '" . str_replace("\'", "''", $interests) . "', user_sig = '" . str_replace("\'", "''", $signature) . "', user_sig_bbcode_uid = '$signature_bbcode_uid', user_viewemail = $viewemail, user_aim = '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', user_yim = '" . str_replace("\'", "''", $yim) . "', user_msnm = '" . str_replace("\'", "''", $msn) . "', user_attachsig = $attachsig, user_allowsmile = $allowsmilies, user_allowhtml = $allowhtml, user_allowbbcode = $allowbbcode, user_allow_viewonline = $allowviewonline, user_notify = $notifyreply, user_notify_pm = $notifypm, user_popup_pm = $popup_pm, user_timezone = $user_timezone, user_dateformat = '" . str_replace("\'", "''", $user_dateformat) . "', user_lang = '" . str_replace("\'", "''", $user_lang) . "', user_style = $user_style, user_active = $user_active, user_actkey = '" . str_replace("\'", "''", $user_actkey) . "'" . $avatar_sql . "
            WHERE user_id = $user_id";
Replace with:
// <!-- BEGIN easyUCP -->
         if ( isset($HTTP_GET_VARS['ucp_mode']) || isset($HTTP_POST_VARS['ucp_mode']) )
            $ucp_mode = ( isset($HTTP_GET_VARS['ucp_mode']) ) ? $HTTP_GET_VARS['ucp_mode'] : $HTTP_POST_VARS['ucp_mode'];
            $ucp_mode = htmlspecialchars($ucp_mode);
// Registration Info
         if ( $ucp_mode == 'ucp_require' || $ucp_mode == '' )
            SET " . $username_sql . $passwd_sql . "user_email = '" . str_replace("\'", "''", $email) ."', user_active = $user_active, user_actkey = '" . str_replace("\'", "''", $user_actkey) . "'
// Profile Info
         if ( $ucp_mode == 'ucp_info' || $ucp_mode == '' )
            SET user_icq = '" . str_replace("\'", "''", $icq) . "', user_website = '" . str_replace("\'", "''", $website) . "', user_occ = '" . str_replace("\'", "''", $occupation) . "', user_from = '" . str_replace("\'", "''", $location) . "', user_interests = '" . str_replace("\'", "''", $interests) . "',user_aim = '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', user_yim = '" . str_replace("\'", "''", $yim) . "', user_msnm = '" . str_replace("\'", "''", $msn) . "'
// Preferences
            SET user_viewemail = $viewemail, user_attachsig = $attachsig, user_allowsmile = $allowsmilies, user_allowhtml = $allowhtml, user_allowbbcode = $allowbbcode, user_allow_viewonline = $allowviewonline, user_allow_viewprofile = $allowviewprofile, user_notify = $notifyreply, user_notify_pm = $notifypm, user_popup_pm = $popup_pm, user_timezone = $user_timezone, user_dateformat = '" . str_replace("\'", "''", $user_dateformat) . "', user_lang = '" . str_replace("\'", "''", $user_lang) . "', user_style = $user_style
// Avatar
         if ( $ucp_mode == 'ucp_avatar' && $avatar_sql != '' || $ucp_mode == '' && $avatar_sql != '' )
            SET " . substr($avatar_sql,2) . "
// Signature
         if ( $ucp_mode == 'ucp_signature' || $ucp_mode == '' )
            SET user_sig_bbcode_uid = '$signature_bbcode_uid', user_sig = '" . str_replace("\'", "''", $signature) . "'
// <!-- END easyUCP -->
However this is whats in my code:
            SET " . $username_sql . $passwd_sql . "user_email = '" . str_replace("\'", "''", $email) ."', user_icq = '" . str_replace("\'", "''", $icq) . "', user_website = '" . str_replace("\'", "''", $website) . "', user_occ = '" . str_replace("\'", "''", $occupation) . "', user_from = '" . str_replace("\'", "''", $location) . "', user_from_flag = '$user_flag', user_interests = '" . str_replace("\'", "''", $interests) . "', user_realname = '" . str_replace("\'", "''", $realname) . "', user_experience = '" . str_replace("\'", "''", $experience) . "', user_experience_bbcode_uid = '$experience_bbcode_uid', user_sig = '" . str_replace("\'", "''", $signature) . "', user_sig_bbcode_uid = '$signature_bbcode_uid', user_viewemail = $viewemail, user_aim = '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', user_yim = '" . str_replace("\'", "''", $yim) . "', user_msnm = '" . str_replace("\'", "''", $msn) . "', user_attachsig = $attachsig, user_allowsmile = $allowsmilies, user_allowhtml = $allowhtml, user_allowbbcode = $allowbbcode, user_allow_viewonline = $allowviewonline, user_notify = $notifyreply, user_notify_pm = $notifypm, user_allow_mass_pm = $allow_mass_pm, user_popup_pm = $popup_pm, user_timezone = $user_timezone, user_dateformat = '" . str_replace("\'", "''", $user_dateformat) . "', user_lang = '" . str_replace("\'", "''", $user_lang) . "', user_style = $user_style, user_active = $user_active, user_actkey = '" . str_replace("\'", "''", $user_actkey) . "'" . $avatar_sql . "
As you can see I have installed some hacks which include realname, mass pm, flags, add new field (the field is called "experience"),.
I really am lost as to how to complete this part of the modification. Please help, I really am lost here...way out of my depth.
gwuk
Beitragvon AmigaLink » 22. Jan 2005 08:26
That is not really a problem. The aditional entries of the existing mods must you only into the new SQL instructions insert. Gild it however to consider it in the correct part to be inserted.
See into yours profile_add_body.tpl where the selection fields are placed and insert their instruction into the appropriate SQL part in usercp_register.php.
For example the realname is placed between <!-- BEGIN switch_ucp_info --> and <!-- END switch_ucp_info -->
Thus you must set its SQL instruction
in part
// Profile Info
so that ist looks like this
// Profile Info
            SET user_icq = '" . str_replace("\'", "''", $icq) . "', user_website = '" . str_replace("\'", "''", $website) . "', user_occ = '" . str_replace("\'", "''", $occupation) . "', user_from = '" . str_replace("\'", "''", $location) . "', user_interests = '" . str_replace("\'", "''", $interests) . "', user_realname = '" . str_replace("\'", "''", $realname) . "',user_aim = '" . str_replace("\'", "''", str_replace(' ', '+', $aim)) . "', user_yim = '" . str_replace("\'", "''", $yim) . "', user_msnm = '" . str_replace("\'", "''", $msn) . "'
Beitragvon gwuk » 22. Jan 2005 17:53
Thanks Amiga :D
I've installed it, just 2 small problems Ive found so far, I will post them one at a time, this is the first I noticed:
There are 2 blank buttons with no text?
gwuk
Beitragvon AmigaLink » 22. Jan 2005 19:42
Did have you made this languange entrys?
$lang['easyUCP'] = '<font color="red">easy</font> User Control Panel';
$lang['Profile_Admin'] = 'User Administration for %s'; // %s is username
$lang['Hide_profile'] = 'Allow Profileview for Guests';
//signature editor
$lang['sig_description'] = "Edit Signature (<b>Preview included</b>)";
$lang['sig_edit'] = "Edit Signature";
$lang['sig_current'] = "Current Signature";
$lang['sig_none'] = '<font color = "red">No Signature available</font>';
$lang['sig_save'] = "Save";
$lang['sig_save_message'] = "Signature saved successful !";
And do you have a test account, so that I can regard that times?
Beitragvon gwuk » 22. Jan 2005 20:39
Ooops, sorry. I forgot to upload the language file :P
The mod has also affected some of the hacks I installed:
My new field I added to the profile
The flags hack
Real name mod (I think Ive found this solution here though)
I have PMed you an admin test account.
gwuk
Beitragvon AmigaLink » 24. Jan 2005 02:40
Thanks for the test account. I will this evening times regard that.
For the realname it gives in the board a Addon is needed here. Did you install?
Beitragvon gwuk » 24. Jan 2005 07:18
Hello Amiga,
Yes I will now install that addon. I had already installed the realname hack on the forum, is this what this addon is for?
Also, will you be needing my FTP info? As I was wondering how I would add back the extra field into the profiles aswell as the flags?
gwuk
Beitragvon AmigaLink » 24. Jan 2005 13:05
Condemned, the server is slow! :?
gwuk hat geschrieben:Hello Amiga,
Yes
For the time being not yet.
Please attach me your:
usercp_register.php
usercp_viewprofile.php
easyucp_body.tpl
and
profile_view_body.tpl
as a zip, rar or ace file.
For what does the experience idt? I can find in addition no entry.
Beitragvon gwuk » 24. Jan 2005 19:10
HI,
I installed the addon, thanks. And here is the rar file.
The experience field was an extra field I added in which people place the experience they have had with which gecko species :)
[center][ Attachment gelöscht am 13.06.2005, 18:45 von AmigaLink ][/center]
gwuk
Beitragvon gwuk » 24. Jan 2005 19:11
Do you know how I can add the realname field to viewprofile? So we can see user's names when we view their profile?
gwuk
