UserCP & Join a Group Upon Registration
Beitragvon Viper » 21. Mär 2006 06:04
Hi, AmigaLink.
I need your help installing "Join a Group Upon Registration" mod with your UserCP mod.
This is the code in have to put in: includes/usercp_register.php
<?php
//// Group Registration Mod
         $sql = "INSERT INTO " . GROUPS_TABLE . " (group_name, group_description, group_single_user, group_moderator)
            VALUES ('', 'Personal User', 1, 0)";
            message_die(GENERAL_ERROR, 'Could not insert data into groups table', '', __LINE__, __FILE__, $sql);
         $group_id = $db->sql_nextid();
// START ADD- Group Registration MOD
         $check_group_id = intval($HTTP_POST_VARS['group_id']);
         if ( !empty ($check_group_id) || $check_group_id > 0)
            // Check to make sure that the group can be joined)
            $sql = "SELECT * FROM " . GROUPS_TABLE . "
               WHERE group_id = $check_group_id and group_allow_reg = " . GROUP_REG;
               message_die(GENERAL_ERROR, 'Could not select data from groups table', '', __LINE__, __FILE__, $sql);
            if ( $db->sql_numrows($result) > 0 )
               $sql = "SELECT group_disable_pending
                  WHERE group_id = $check_group_id";
                  message_die(GENERAL_ERROR, 'Could not select group pending settings', '', __LINE__, __FILE__, $sql);
               if ( !($row = $db->sql_fetchrow($result)) )
                  message_die(GENERAL_ERROR, 'Could not fetchrow group pending settings', '', __LINE__, __FILE__, $sql);
               // Check to see if pending status is enabled for this group
               if ( $row['group_disable_pending'] == GROUP_PEND )
                  $pending = 0;
               } else {
                  $pending = 1;
               $group_sql = "INSERT INTO " . USER_GROUP_TABLE . " (user_id, group_id, user_pending)
                     VALUES ($user_id, $check_group_id, $pending)";
               if( !($result = $db->sql_query($group_sql, END_TRANSACTION)) )
                  message_die(GENERAL_ERROR, 'Could not insert data into user_group table', '', __LINE__, __FILE__, $sql);
         } else {
            // Check to see if users have to join a group (only necessary if a hacker has devised a work-around: security check)
            if ( $board_config['group_force_reg'] == GROUP_FORCE )
               message_die(GENERAL_MESSAGE, $lang['No_group_specified']);
// END ADD- Group Registration MOD
   $smilies_status = ( $userdata['user_allowsmile'] && $board_config['allow_smilies']  ) ? $lang['Smilies_are_ON'] : $lang['Smilies_are_OFF'];
   if ( $mode == 'register' )
      $ignore_group_sql =   ( count($in_group) ) ? "AND group_id NOT IN (" . implode(', ', $in_group) . ")" : '';
      $sql = "SELECT group_id, group_name, group_type
         FROM " . GROUPS_TABLE . " g
         WHERE group_single_user <> " . TRUE . "
         $ignore_group_sql and
         group_allow_reg = " . GROUP_REG . "
         ORDER BY g.group_name";
         message_die(GENERAL_ERROR, 'Error getting group information', '', __LINE__, __FILE__, $sql);
      $s_group_list_opt = '';
      // If there are no joinable usergroups
      if ( $db->sql_numrows($result) <= 0 )
         $s_group_list_opt .='<option value="0">' . $lang['No_usergroups_reg'] . '</option>';
      // If usergroup registration is not forced
      if ( $board_config['group_force_reg'] == GROUP_NO_FORCE && $db->sql_numrows($result) > 0 )
         $s_group_list_opt .='<option value="0">' . $board_config['group_default_none'] . '</option>';
      // Create loop
         if  ( $row['group_type'] != GROUP_HIDDEN || $userdata['user_level'] == ADMIN )
            $s_group_list_opt .='<option value="' . $row['group_id'] . '">' . $row['group_name'] . '</option>';
      $s_group_list = '<select name="group_id">' . $s_group_list_opt . '</select>';
      $template->assign_var('L_USERGROUP_SELECT' , $s_group_list );
      $template->assign_block_vars('switch_select_usergroup',array());
      'CONFIRM_IMG' => $confirm_image,
      'USERGROUP_SELECT' => $s_group_list,
      'L_RESET' => $lang['Reset'],
      'L_USERGROUP' => $lang['Usergroup'],
# Already Added
templates/subSilver/profile_add_body.tpl
     <td class="row2" colspan="2"><span class="gensmall">{L_PROFILE_INFO_NOTICE}</span></td>
   <!-- BEGIN switch_select_usergroup -->
     <td class="row1"><span class="gen">{L_USERGROUP}:</span></td>
     <td class="row2">
      {USERGROUP_SELECT}
     </td>
   <!-- END switch_select_usergroup -->
Where would I add these changes for the userCP mod.
Thanks for your time and a great mod.
Link to text file: ( Join a Group Upon Registration )
Viper
Beitragvon AmigaLink » 22. Mär 2006 11:02
Install the MOD like the guide and then attach me the usercp_register.php and the profile_add_body.tpl in a zip file.
Then I can look at this whitout install the MOD myself and change some little things for you. :)
