How to activate the userpic in profile ?
Beitragvon flesheater » 20. Dez 2006 18:15
I think I installed it on my boar correctly, but the form for uploading image is not showing in the page, from where the user edits his profile...
In the code of the page is added correctly to code for adding the upload form and the menu of the mod but it is not showing in the browser ...
must it be activated somehow ? In my admin menu I see only the option to set the size of the picture ...
flesheater
Beitragvon AmigaLink » 20. Dez 2006 18:27
No there ist nothing to activate.
Check your usercp_register.php and your profile_add_body.tpl
Beitragvon flesheater » 20. Dez 2006 18:37
AmigaLink hat geschrieben:No there ist nothing to activate.
everything is just on it's place ...
flesheater
Beitragvon AmigaLink » 20. Dez 2006 19:10
That cannot be. Then it would function. ;)
Did you high-load the files to the server :?:
I am unfortunately no witch. :roll:
Please fill your support informations and attach the usercp_register.php as well as the profile_add_body.tpl.
Zurück zu Userpic in Profile
