[Addon] Add Status To Topic & UPI2DB - Mark Edit On Status Change
Beitragvon AmigaLink » 1. Mai 2007 21:42
Der http://www.amigalink.de/download ... tail&id=61 MOD von Acid ist, dank seiner Modularen Installationsanleitung (in form von beigelegten addons), ein Präfix MOD der sich sehr schön an die eigenen Bedürfnisse anpassen lässt. :)
Dieses kleine Snippet bewirkt das der erste Beitrag eines threads, vom UPI2DB, als editiert angezeigt wird, wenn der Status des Topics geändert wurde.
viewtopic.php
# Note the original line will be much longer
$sql = "SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_info, t.topic_status, t.topic_replies, t.topic_time, t.topic_type, t.topic_vote, t.topic_last_post_id,
t.topic_vote
, t.topic_first_post_id
   $message = $lang['Topic_info_updated'] .'<br /><br />'. sprintf($lang['Click_return_topic'], '<a href="'. append_sid("viewtopic.$phpEx?". POST_TOPIC_URL ."=$topic_id") .'">', '</a>') .'<br /><br />'. sprintf($lang['Click_return_forum'], '<a href="'. append_sid("viewforum.$phpEx?". POST_FORUM_URL ."=$forum_id") .'">', '</a>');
//<!-- BEGIN Unread Post Information to Database Mod -->
   if($board_config['upi2db_on'])
      $sql = "SELECT post_id FROM " . UPI2DB_LAST_POSTS_TABLE . " WHERE post_id = " . $forum_topic_data['topic_first_post_id'];
      if ($result = $db->sql_query($sql))
         $id_vorhanden = $db->sql_numrows($result);
      $db->sql_freeresult($result);
      if ($id_vorhanden == 0)
         $sql = "INSERT INTO " . UPI2DB_LAST_POSTS_TABLE . " (post_id, topic_id, forum_id, poster_id, post_edit_time, topic_type, post_edit_by) VALUES ('".$forum_topic_data['topic_first_post_id']."', '".$forum_topic_data['topic_id']."', '".$forum_topic_data['forum_id']."', '" . $userdata['user_id'] . "', '".time()."', '".$forum_topic_data['topic_type']."', '" . $userdata['user_id'] . "')";
         $sql = "UPDATE " . UPI2DB_LAST_POSTS_TABLE . " SET post_edit_time = '" . time() . "', topic_type = '" . $forum_topic_data['topic_type'] . "', post_edit_by = '" . $userdata['user_id'] . "' WHERE post_id = " . $forum_topic_data['topic_first_post_id'];
      if (!$db->sql_query($sql))
         message_die(GENERAL_ERROR, 'Error in posting (UPI2DB)', '', __LINE__, __FILE__, $sql);
//<!-- END Unread Post Information to Database Mod -->
Ich selber finde diese Funktion zwar eher lästig als nützlich. Aber je nach Anwendungsgebiet des 'Add Status To Topic', mag es vielleicht sogar einen Sinn ergeben. :)
Beitragvon HammerBe » 2. Mai 2007 13:28
Jawohl das klapt bestens.Hezlichen dank :D
Gucksdu Morgen
HammerBe
Mitglieder in diesem Forum: Majestic-12 [Bot] und 1 Gast
