URL Button vereinfachen mit JS
Beitragvon mgutt » 16. Dez 2004 17:03
Ich habe auch einen :wink:
## Mod Title:      URL Query (BBcode)
## Mod Author:      oxpus http://www.oxpus.de edit by mgutt http://www.maxrev.de
## Mod Description:   a little comfort URL Query based on Javascript
## Mod Version:      1.0.0
## Installation Level:   Easy
## Installation Time:   5 Minutes
## Files To Edit:   templates/subSilver/posting_body.tpl
##          language/lang_english/lang_main.php
##          language/lang_german/lang_main.php
##          posting.php
##          privmsg.php
## Included Files:   n/a
## Before Adding This Mod To Your Forum, You Should Back Up All Files Related To This Mod
#-----[ OPEN ]-----
#-----[ FIND ]-----
// Shows the help messages in the helpline window
function helpline(help) {
   document.post.helpbox.value = eval(help + "_help");
#-----[ AFTER, ADD ]-----
function BBCurl() {
   var FoundErrors = '';
   var enterURL   = prompt("{L_BBCURL_URL}", "http://");
   var enterTITLE = prompt("{L_BBCURL_NAME}", "{L_BBCURL_DESC}");
   if (!enterURL)    {
      FoundErrors += "{L_BBCURL_NO_URL}";
   if (!enterTITLE)  {
      FoundErrors += "{L_BBCURL_NO_NAME}";
   if (FoundErrors)  {
      alert("Error"+FoundErrors);
      return;
   var ToAdd = "[URL="+enterURL+"]"+enterTITLE+"[/URL]";
   document.post.message.value+=ToAdd;
   document.post.message.focus();
#-----[ FIND ]-----
<td>
<input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="width: 52px" onclick="bbstyle(16)" onmouseover="helpline('w')" />
</td>
#-----[ REPLACE WITH ]-----
<td>
<input type="button" class="button" accesskey="w" name="addbbcode16" value="URL" style="width: 52px" onClick="BBCurl()" onMouseOver="helpline('w')" />
</td>
#-----[ OPEN ]-----
#-----[ FIND ]-----
$lang['bbcode_f_help'] = 'Font size: [size=x-small]small text[/size]';
// URL Query by www.oxpus.de edit by www.maxrev.de
$lang['bbcurl_url'] = 'What is the URL?';
$lang['bbcurl_name'] = 'Please add the Name of the URL.';
$lang['bbcurl_desc'] = 'Description';
$lang['bbcurl_no_url'] = 'You did not add a URL!';
$lang['bbcurl_no_name'] = 'You did not add a name!';
#-----[ OPEN ]-----
#-----[ FIND ]-----
$lang['bbcurl_url'] = 'Wie lautet die Internetadresse (URL)?';
$lang['bbcurl_name'] = 'Gebe jetzt den Namen für die Internetadresse (URL) ein.';
$lang['bbcurl_desc'] = 'Beschreibung';
$lang['bbcurl_no_url'] = 'Du hast keine Internetadresse (URL) angegeben!';
$lang['bbcurl_no_name'] = 'Du hast keinen Namen für die Internetadresse (URL) angegeben!';
#-----[ OPEN ]-----
posting.php
#-----[ FIND ]-----
   'L_EMPTY_MESSAGE' => $lang['Empty_message'],
   'L_BBCURL_URL' => $lang['bbcurl_url'],
   'L_BBCURL_NAME' => $lang['bbcurl_name'],
   'L_BBCURL_DESC' => $lang['bbcurl_desc'],
   'L_BBCURL_NO_URL' => $lang['bbcurl_no_url'],
   'L_BBCURL_NO_NAME' => $lang['bbcurl_no_name'],
#-----[ OPEN ]-----
privmsg.php
#-----[ FIND ]-----
#-----[ SAVE/CLOSE ALL FILES ]-----
hier fing alles an ;)
http://www.oxpus.de/phpBB/viewtopic.php?t=844
mgutt
Beitragvon AmigaLink » 16. Dez 2004 20:57
Cool - Thx :)
