[Addon] Add Status To Topic - Delete Status
Beitragvon AmigaLink » 1. Mai 2007 09:00
Der http://www.amigalink.de/download ... tail&id=61 MOD von Acid ist, dank seiner Modularen Installationsanleitung (in form von beigelegten addons), ein Präfix MOD der sich sehr schön an die eigenen Bedürfnisse anpassen lässt. :)
Dieses kleine Snippet hier, ermöglicht es nun dem Admin und den Moderatoren den Status eines Topics auch wieder zu Löschen. 8)
$lang['Topic_info_updated'] = 'Topic Info updated.';
$lang['Topic_info_delete'] = 'delete Topic Info';
$lang['Topic_info_updated'] = 'Topic Info aktualisiert.';
$lang['Topic_info_delete'] = 'Topic Info löschen';
viewtopic.php
   global $topic_info, $lang;
$lang
, $userdata
   $s_info_select .= '</select>';
   $s_info_select .= ($topic_info != '0' && ($userdata['user_level'] == ADMIN || $userdata['user_level'] == MOD)) ? '<option value="-1">' . $lang['Topic_info_delete'] . '</option>' : '';
   $sql = "UPDATE ". TOPICS_TABLE ." SET topic_info = '". str_replace("\'", "''", $HTTP_POST_VARS['topic_info']) ."' WHERE topic_id = $topic_id";
   if( !$db->sql_query($sql) )
      message_die(GENERAL_ERROR, 'could not update topic info.', '', __LINE__, __FILE__, $sql);
   $message = $lang['Topic_info_updated'] .'<br /><br />'. sprintf($lang['Click_return_topic'], '<a href="'. append_sid("viewtopic.$phpEx?". POST_TOPIC_URL ."=$topic_id") .'">', '</a>') .'<br /><br />'. sprintf($lang['Click_return_forum'], '<a href="'. append_sid("viewforum.$phpEx?". POST_FORUM_URL ."=$forum_id") .'">', '</a>');
   message_die(GENERAL_MESSAGE, $message);
   $topic_info_status = intval($HTTP_POST_VARS['topic_info']);
   if ($topic_info_status != 0)
      ($topic_info_status == -1) ? $topic_info_status = 0 :'';
      $sql = "UPDATE ". TOPICS_TABLE ." SET topic_info = $topic_info_status WHERE topic_id = $topic_id";
      if ( !$db->sql_query($sql) )
         message_die(GENERAL_ERROR, 'Could not update topic info.', '', __LINE__, __FILE__, $sql);
      $message = $lang['Topic_info_updated'] . "<br /><br />" . sprintf($lang['Click_return_topic'], "<a href=\"" . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id") . "\">", "</a>") . "<br /><br />" . sprintf($lang['Click_return_forum'], "<a href=\"" . append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id") . "\">", "</a>");
Beitragvon HammerBe » 1. Mai 2007 15:36
das ist bei mir wieder anders,Ich habe das mall so umgetauscht leider kann man das nicht löschen.
[center][- Codeblock vom Admin gelöscht -][/center]
Gucksdu Morgen
HammerBe
Beitragvon AmigaLink » 1. Mai 2007 21:55
:x Was hast du denn da gemacht?
Wie dem auch sei, poste mir mal die original Zeilen von dir.
Beitragvon HammerBe » 2. Mai 2007 00:43
Das sind die originallen
      SET topic_info = '". str_replace("\'", "''", $HTTP_POST_VARS['topic_info']) ."', topic_info_poster = '". $userdata['username'] ."', topic_info_time = '". time() ."', topic_info_changed = topic_info_changed + 1
Gucksdu Morgen
HammerBe
Beitragvon AmigaLink » 2. Mai 2007 11:25
Ah - ok, dann ersetz den Block mal gegen diesen:
         SET topic_info = $topic_info_status, topic_info_poster = '". $userdata['username'] ."',
Beitragvon HammerBe » 2. Mai 2007 13:17
und wie lösche ich sie? ich sehe nix zum löschen.
Gucksdu Morgen
HammerBe
Beitragvon AmigaLink » 2. Mai 2007 17:24
In der Statusauswahl haben Admins und Moderatoren nun, als letzten Punkt, 'Topic Info löschen'. Auswählen, absenden, fertig. :)
Beitragvon HammerBe » 2. Mai 2007 19:05
naja so hatte ich auch gedacht aber ich sehe bei mir kein Topic Info löschen.
ich habe die anderen snipped eingebaut und jetz ist auch der code anders.
Ich hönge mal meine wievtopic.php an.Gucksdu bitte mall nach.
Danke
viewtopic.rar
(27.85 KiB) 5182-mal heruntergeladen
Gucksdu Morgen
HammerBe
Beitragvon AmigaLink » 2. Mai 2007 21:35
Hättest du das http://www.amigalink.de/viewtopic.php?t=1095 zuletzt eingebaut, dann hättest du aber keine Probleme bekommen. ;)
Ansonsten muss ich zugeben das es ohne PHP Kenntnisse sehr schwer ist, mehrere Snippets einzubauen die alle den selben Codeteil bearbeiten. :roll:
Wenn du die Eintragungen in der lang_main.php gemacht hast, dann sollte es mit den angehangenen Datei Funktionieren. :)
viewtopic.zip
(25.57 KiB) 5154-mal heruntergeladen
Beitragvon HammerBe » 2. Mai 2007 21:53
also das komisch status löschen ist immer noch nicht zu sehen.Ich habe das bei lang-main.php eingetragen. :?
Gucksdu Morgen
HammerBe
