Last Knowledge Base articles on ezPortal
Beitragvon AmigaLink » 26. Mär 2005 21:43
Zeigt die letzten 5 Artikel, aus dem Knowledge Base, im ezPortal an.
portal.php
// Generate the page
$template->pparse('body');
// Latest Kb Article
$sql = "SELECT * FROM " . $table_prefix . "kb_articles ORDER BY article_date DESC LIMIT 0,5";
   message_die(GENERAL_ERROR, 'Could not query database for the most downloads');
$template->assign_vars(array(
   'TITLE_LATEST_KB' => $lang['Latest_kb'])
$i = 1;
while ($file_latest = $db->sql_fetchrow($result))
   $template->assign_block_vars('kbrow', array(
      'FILELINK_LATEST_KB' => append_sid("kb.php?mode=article&k=" . $file_latest['article_id']),
      'FILENAME_LATEST_KB' => (strlen($file_latest['article_title']) >= 40 ) ? substr($file_latest['article_title'], 0, 37).'...' : $file_latest['article_title'],
      'DATE_LATEST_KB' => create_date($board_config['default_dateformat'], $file_latest['article_date'], $board_config['board_timezone']))
   $i++;
templates/subSilver/portal_body.tpl
        <table width="100%" cellpadding="2" cellspacing="1" border="0" class="forumline">
         <td class="catHead" height="25"><span class="genmed"><b>{L_STATISTICS}</b></span></td>
         <td class="row1" align="left"><span class="gensmall">{TOTAL_USERS}<br />{NEWEST_USER}<br /><br/>{TOTAL_POSTS} {TOTAL_TOPICS}<br />&nbsp;</span></td>
        </table>
        <br />
<!-- Latest Article -->
      <td class="catHead" height="25"><span class="genmed"><b>{TITLE_LATEST_KB}</b></span></td>
<!-- BEGIN kbrow -->
      <td class="row1"><span class="gensmall">&nbsp;&raquo;&nbsp;<a href="{kbrow.FILELINK_LATEST_KB}">{kbrow.FILENAME_LATEST_KB}</a>&nbsp;-&nbsp;{kbrow.DATE_LATEST_KB}&nbsp;</span></td>
<!-- END kbrow -->
      <td class="row2">&nbsp;</td>
</table>
<br />
<!-- / Latest Article -->
$lang['Latest_kb'] = 'Last article in Knowledge Base';
$lang['Latest_kb'] = 'Letzte Artikel in der Knowledge Base';
Beitragvon dash » 4. Nov 2006 21:31
ich möchte die neusten Artikel nur aus einer bestimmten Kategorie der Knowledge Base anzeigen . Wie stelle ich das an ?
Könnt ihr mir da helfen ?
Vielen Dank im vorraus
dash
Beitragvon AmigaLink » 5. Nov 2006 13:17
Kein Problem. :)
$access_kb_cats = '1, 2';
WHERE article_category_id IN ('" . $access_kb_cats . "')
$access_kb_cats = '1, 2'; gibt an das Kategorien mit der id 1 und 2 angezeigt werden sollen. Ersetz also 1, 2 gegen die Kategorie(n) die du anzeigen möchtest.
Beitragvon dash » 5. Nov 2006 14:42
yo danke für die schnelle Antwort,
ich hab noch ein Problem das ich mehrere Blöcke auf meiner Seite habe und die sollen aus verschiedenen Kategorien die jeweiligen Artikel anzeigen .
Ich hab zum Beispiel ein Block für Nachrichten Archiv und ein block für News Aktuell.
was muss ich ändern oder erweitern damit dies passieren kann ?
thx
dash
Beitragvon AmigaLink » 5. Nov 2006 15:20
In dem Fall machst du das besser so:
WHERE article_category_id = 1
WHERE article_category_id = 1 bestimmt wieder die angezeigte Kategorie. Wenn du das Snippet mehrmals einbaust, musst du bei jedem zusätzlichem Block diese Kategorie anpassen.
Ausserdem musst du die Platzhalter für jeden zusätzlichen Block anpassen. Zum Beispiel so:
portal.php
   $template->assign_block_vars('kbrow_2', array(
<!-- BEGIN kbrow_2 -->
<!-- END kbrow -->
<!-- END kbrow_2 -->
Beitragvon smarty » 5. Jan 2008 14:59
Super, dieser Snippet :)
Anbei eine Frage:
es werden alle Artikel ausgegeben, auch wenn für bestimmte Artikel keine Readrechte bestehen.
Jetzt habsch es so geändert
$i = 1;
      if ( $file_latest['auth_view'])
       'FILELINK_LATEST_KB' => append_sid("wb.php?mode=article&k=" . $file_latest['article_id']),
       'FILENAME_LATEST_KB' => (strlen($file_latest['article_title']) >= 24 ) ? substr($file_latest['article_title'], 0, 23).'...' : $file_latest['article_title'])
    $i++;
wodurch nun garnix angezeigt wird :?
Website kann ich leider nicht nennen, da ich alles local liegen habe.
smarty
Mitglieder in diesem Forum: 0 Mitglieder und 33 Gäste
