How Can I have the scrolling links in my Portal ??
Beitragvon mariocaz » 25. Jun 2005 22:04
Hello Amigalink!! :)
I want to see scrolling the links than I have in the Links Block of my ezPortal exactly that you have in your Portal with the buttons and all stuff in this excellent site. :wink:
This is my site:
www.all-reefs.com
What Can I do for that ?? :?
mariocaz
Beitragvon AmigaLink » 25. Jun 2005 22:19
Here on amigalink.de is it a part of the IM-Portal but original it is the Q_Links on ezPortal MOD from OXPUS. :D
Beitragvon mariocaz » 25. Jun 2005 22:21
With the Q_Links on ezPortal from Oxpus I can have exactly this ?
mariocaz
Beitragvon AmigaLink » 25. Jun 2005 22:22
Yes
Beitragvon mariocaz » 25. Jun 2005 22:23
Because I already have the links block in the Portal
Added after 48 seconds:
And I only want the scrolling links and the buttons.
mariocaz
Beitragvon AmigaLink » 25. Jun 2005 22:28
You have the original ezPortal Links Block from Smartor. That is not the same and must be remove if you want only have the scrolling one.
Beitragvon mariocaz » 25. Jun 2005 22:35
UFFFF but this block works with the Complete Banner MOD. (all of that are in the package of the phpBB plus)
I think it will be very very difficult to remove it.
If I only want the scrolling and the buttons can you help me with the Modifications ??
Because I have already the block and ACP options of this.
mariocaz
Beitragvon AmigaLink » 25. Jun 2005 23:25
No that isn't difficult!
You only must remove or comment out the block in your portal_body.tpl :)
Beitragvon mariocaz » 25. Jun 2005 23:28
I think a little modifications in some of my files will help me. :P
Some like you do in the IM Portal to have your links like this. :mrgreen:
Added after 3 minutes:
Because like I said... I already have the links block in the portal and the options to manage this in the ACP.
mariocaz
Beitragvon AmigaLink » 25. Jun 2005 23:42
You missunderstand me.
The original links Block (from Smartor), that is a little bit modified by Stefan (plus board), is only an entry in the portal_body.tpl!
Remove that entry, install the Q_Links on ezPortal MOD and you have exact the same block like mine! :D
Zugefügt nach 13 Minute(n):
Your options in the ACP to Manage the links block are from the Complete Banner MOD and cann be used to place Banners on other places of your board. Or you can combine it with the Q_Links. ;)
Mitglieder in diesem Forum: Majestic-12 [Bot] und 2 Gäste
