[Bugfix] Knowledge Base mx 2.0.2
Beitragvon AmigaLink » 24. Aug 2005 22:35
Diverse Fixe für die Knowledge Base mx 2.0.2
#-----[ OPEN ]-----
includes/functions_kb.php
#-----[ FIND ]-----
      "'\[quote*?[^\[\]]*?\]'si",
      "'\[\/quote*?[^\[\]]*?\]'si",
#-----[ REPLACE WITH ]-----
//      "'\[toc*?[^\[\]]*?\]'si",
//      "'\[\/toc*?[^\[\]]*?\]'si",
#-----[ FIND ]-----
      "<div align=\"center\"><span class=\"gensmall\"><i>''",
      "''</i></span></div>",
//      "<div align=\"left\"><span class=\"genmed\"><u>",
//      "</u></span></div>",
#-----[ OPEN ]-----
includes/kb_article.php
#-----[ FIND ]-----
$article = make_clickable( $article );
#-----[ AFTER, ADD ]-----
$article = article_formatting( $article );
#-----[ FIND ]-----
         'PAGE_NUMBER' => sprintf( $lang['Page_of'], ( floor( $start / $kb_config['comments_pagination'] ) + 1 ), ceil( $num_of_replies / $kb_config['comments_pagination'] ) ),
         'PAGE_NUMBER' => ($num_of_replies > $kb_config['comments_pagination']) ? sprintf( $lang['Page_of'], ( floor( $start / $kb_config['comments_pagination'] ) + 1 ), ceil( $num_of_replies / $kb_config['comments_pagination'] ) ) : '',
#-----[ OPEN ]-----
includes/kb_cat.php
#-----[ FIND ]-----
   if ( $total_articles > 0 )
   if ( $total_articles > $kb_config['art_pagination'] )
#-----[ OPEN ]-----
includes/kb_header.php
#-----[ FIND ]-----
      'L_PORTAL' => "<<",
# // Choose yourself the right link and text you wants!!!
      'L_PORTAL' => '<a href="'.append_sid("portal.$phpEx").'" class="genmed">'.$lang['Portal'].'</a>',
#-----[ OPEN ]-----
templates/subSilver/kb_article_body.tpl
#-----[ FIND ]-----
      <td align="left" class="nav">
        <a href="{U_KB}" class="nav">{L_KB}</a> {PATH}
      </td>
      <td align="right" class="nav">
        <a href="{U_PRINT}" class="nav">{L_PRINT}</a>
      </td>
      <td align="left" class="nav">{L_PORTAL} <b>&raquo;</b> <a href="{U_KB}" class="nav">{L_KB}</a> {PATH}</td>
      <td align="right" class="nav"><a href="{U_PRINT}" class="nav">{L_PRINT}</a></td>
#-----[ FIND ]-----
      <span class="maintitle"style="font-size: 9pt;">{ARTICLE_TITLE}</span>
      <span class="maintitle"style="font-size: 22pt;"><b>{ARTICLE_TITLE}</b></span>
#-----[ OPEN ]-----
templates/subSilver/kb_cat_body.tpl
#-----[ FIND ]-----
      </td>
#-----[ OPEN ]-----
templates/subSilver/kb_índex_body.tpl
#-----[ FIND ]-----
      <td align="left" class="nav"><a href="{U_KB}" class="nav">{L_KB}</a></td>
      <td align="left" class="nav">{L_PORTAL} <b>&raquo;</b> <a href="{U_KB}" class="nav">{L_KB}</a></td>
#-----[ OPEN ]-----
templates/subSilver/kb_rate_body.tpl
#-----[ FIND ]-----
      <input type="hidden" name="action" value="rate">
      <input type="hidden" name="id" value="{ID}">
      <input type="hidden" name="rate" value="dorate">
      </select>
      </select>
#-----[ OPEN ]-----
templates/subSilver/kb_search_body.tpl
#-----[ FIND ]-----
      <td align="left"><span class="nav"><a href="{U_KB}" class="nav">{L_KB}</a></span></td>
      <td align="left"><span class="nav">{L_PORTAL} <b>&raquo;</b> <a href="{U_KB}" class="nav">{L_KB}</a></span></td>
#-----[ OPEN ]-----
templates/subSilver/kb_search_results.tpl
#-----[ FIND ]-----
#-----[ OPEN ]-----
templates/subSilver/kb_stats_body.tpl
#-----[ FIND ]-----
      </td>
#-----[ OPEN ]-----
templates/subSilver/admin/kb_cat_admin_body.tpl
#-----[ FIND ]-----
<form action="{S_ACTION}" method="GET">
#-----[ REPLCE WITH ]-----
<form action="{S_ACTION}" method="post">
#-----[ OPEN ]-----
templates/subSilver/admin/kb_type_body.tpl
#-----[ FIND ]-----
#-----[ SAVE/CLOSE ALL FILES ]-----
Quelle
Zugefügt nach 12 Tag(en) 5 Stunde(n) 10 Minute(n):
Durch die Änderung in der includes/functions_kb.php wird die [toc] Funktion zerstört. :?
Ich habe deswegen den Codeblock angepasst und die schuldigen Zeilen auskommentiert. Wer möchte kann sie auch einfach löschen. ;)
// EDIT
Wie ich eben feststellen musste sind diese fixes von oxpus. Ich hab die Quelle also mal schnell korrigiert!
Zuletzt geändert von AmigaLink am 25. Aug 2005 00:23, insgesamt 1-mal geändert.
Beitragvon AmigaLink » 25. Aug 2005 00:00
Und noch ein Fix von mir:
#-----[ OPEN ]-----
#-----[ FIND ]-----
      // insert the actual post text for our new post
      $sql = "INSERT INTO " . POSTS_TEXT_TABLE . " (post_id, post_subject, bbcode_uid, post_text) VALUES ($post_id, '$subject', '$bbcode_uid', '$message_update_text')";
      if ( !$db->sql_query( $sql, BEGIN_TRANSACTION ) )
         $error_die_function( GENERAL_ERROR, 'Error in posting', '', __LINE__, __FILE__, $sql );
      if ( $mode == 'newtopic' )
         $sql = "INSERT INTO " . POSTS_TEXT_TABLE . " (post_id, post_subject, bbcode_uid, post_text) VALUES ($post_id, '$subject', '$bbcode_uid', '$message')";
Zuletzt geändert von AmigaLink am 25. Aug 2005 13:26, insgesamt 2-mal geändert.
Beitragvon AmigaLink » 25. Aug 2005 00:16
Und noch einer (von modbo):
# ----- [ OPEN ] -----
kb_footer.php
# ----- [ FIND ] -----
'L_QUICK_NAV' => $lang['Quick_nav'],
# ----- [ AFTER, ADD ] -----
'L_QUICK_CAT' => $lang['Quick_cat'],
kb_footer.tpl
{L_QUICK_JUMP}
# ----- [ REPLACE, WITH ] -----
{L_QUICK_CAT}
language/lang_german/lang_kb.php
$lang['Quick_nav'] = 'Quick KB Navigation';
$lang['Quick_cat'] = 'Übersicht';
Quelle
Beitragvon AmigaLink » 25. Aug 2005 00:38
Und noch einer von oxpus:
function kb_mailer(
   $to_id,
   $message,
   $subject,
   $from_id,
   $html_on = 0,
   $bbcode_on = 1,
   $smilies_on = 1)
   global $db, $lang, $user_ip, $board_config, $userdata, $phpbb_root_path, $phpEx;
   if ( !$from_id )
      $from_id = $userdata['user_id'];
   //get varibles ready
   $to_id = intval($to_id);
   $from_id = intval($from_id);
   $msg_time = time();
   $attach_sig = $userdata['user_attachsig'];
   //get to users info
   $sql = "SELECT user_id, user_notify_pm, user_email, user_lang, user_active
      FROM " . USERS_TABLE . "
      WHERE user_id = '$to_id'
         AND user_id <> " . ANONYMOUS;
      $error = TRUE;
      $error_msg = $lang['No_such_user'];
   $to_userdata = $db->sql_fetchrow($result);
   $privmsg_subject = trim(strip_tags($subject));
   if ( empty($privmsg_subject) )
      $error = TRUE;
      $error_msg .= ( ( !empty($error_msg) ) ? '<br />' : '' ) . $lang['Empty_subject'];
   if ( !empty($message) )
      if ( !$error )
         if ( $bbcode_on )
            $bbcode_uid = make_bbcode_uid();
         $privmsg_message = prepare_message($message, $html_on, $bbcode_on, $smilies_on, $bbcode_uid);
         $privmsg_message = str_replace('\\\n', '\n', $privmsg_message);
      $error = TRUE;
      $error_msg .= ( ( !empty($error_msg) ) ? '<br />' : '' ) . $lang['Empty_message'];
   $script_name = preg_replace('/^\/?(.*?)\/?$/', "\\1", trim($board_config['script_path']));
    $script_name = ( $script_name != '' ) ? $script_name . '/privmsg.'.$phpEx : 'privmsg.'.$phpEx;
    $server_name = trim($board_config['server_name']);
    $server_protocol = ( $board_config['cookie_secure'] ) ? 'https://' : 'http://';
    $server_port = ( $board_config['server_port'] <> 80 ) ? ':' . trim($board_config['server_port']) . '/' : '/';
    include($phpbb_root_path . 'includes/emailer.'.$phpEx);
    $emailer = new emailer($board_config['smtp_delivery']);
    $emailer->from( $board_config['board_email'] );
    $emailer->replyto( $board_config['board_email'] );
    $emailer->email_address($to_userdata['user_email'] );
    $emailer->set_subject( $privmsg_subject );
   $emailer->msg = $privmsg_message;
    $emailer->send();
    $emailer->reset();
// get categories for index
function kb_mailer($to_id, $message, $subject, $from_id, $html_on = 0, $bbcode_on = 1, $smilies_on = 1)
   if ( !$from_id )
   $msg_time = time();
   //get to users info
   $sql = "SELECT user_id, username, user_notify_pm, user_email, user_lang, user_active
      $error = TRUE;
      $error = TRUE;
      if ( !$error )
         $message = strip_tags($message);
         $message = str_replace("[i]", '', $message);
         $message = str_replace("[/i]", '', $message);
         $message = str_replace("[b]", '', $message);
         $message = str_replace("[/b]", '', $message);
         $message = str_replace('[url=', '', $message);
         $message = str_replace('[/url]', ')', $message);
         $message = str_replace(']', ' (', $message);
         $message = unprepare_message($message);
       $message = preg_replace('/(/', '(', $message);
       $message = preg_replace('/)/', ')', $message);
       $message = preg_replace('/:/', ':', $message);
       $message = preg_replace('/[/', '[', $message);
       $message = preg_replace('/]/', ']', $message);
       $message = preg_replace('/{/', '{', $message);
       $message = preg_replace('/}/', '}', $message);
         $message = str_replace('\n', "\n", $message);
      $error = TRUE;
   $script_name = ( $script_name != '' ) ? $script_name . '/kb.'.$phpEx : 'kb.'.$phpEx;
   $emailer->use_template('kb_notify', $to_userdata['user_lang']);
   $emailer->assign_vars(array(
      'USERNAME' => $to_userdata['username'],
      'SITENAME' => $board_config['sitename'],
      'EMAIL_SIG' => (!empty($board_config['board_email_sig'])) ? str_replace('<br />', "\n", "-- \n" . $board_config['board_email_sig']) : '',
      'MESSAGE' => $message)
   $emailer->send();
   $emailer->reset();
Vorsicht, hier gibt es eine Fehlerhafte Darstellung im Codeblock. Deswegen ist der code auch nochmal in dem attachment enthalten!
kb_notify.tpl.zip
(2.83 KiB) 6346-mal heruntergeladen
Zuletzt geändert von AmigaLink am 3. Sep 2005 18:10, insgesamt 2-mal geändert.
Beitragvon AmigaLink » 25. Aug 2005 01:19
Und ich nochmal:
   // if this is a new topic then insert the topic details
   if ( empty( $topic_id ) )
      $mode = 'newtopic';
      $sql = "INSERT INTO " . TOPICS_TABLE . " (topic_title, topic_poster, topic_time, forum_id, topic_status, topic_type, topic_vote) VALUES ('$subject', " . $user_id . ", $current_time, $forum_id, " . TOPIC_UNLOCKED . ", $topic_type, $topic_vote)";
      $topic_id = $db->sql_nextid();
      $mode = 'newtopic';
      $sql = "SELECT topic_first_post_id
            FROM " . TOPICS_TABLE . "
            WHERE topic_id = $topic_id";
      if ( !( $result = $db->sql_query( $sql ) ) )
         $error_die_function( GENERAL_ERROR, "Could not obtain orig_post_id data", '', __LINE__, __FILE__, $sql );
      $row = $db->sql_fetchrow( $result );
      $first_post_id = $row['topic_first_post_id'];
      $sql = "UPDATE " . POSTS_TABLE . " SET
                post_edit_time = $current_time, post_edit_count = post_edit_count + 1
         WHERE post_id = $first_post_id
         AND topic_id = $topic_id";
      if ( !$db->sql_query( $sql, END_TRANSACTION ) )
Hiermit wird, jedesmal wenn ein KB-Artikel bearbeitet wird, der Editierungszähler vom erstem Beitrag des KB-Threads (im Forum) hochgesetzt. :)
Ist ganz interessant wenn das Bumping nicht aktiviert ist.
Beitragvon AmigaLink » 3. Sep 2005 01:31
Und noch ein Fix von oxpus:
includes/kb_post.php
         if ( $kb_is_auth['auth_mod'] || $kb_is_auth['auth_approval_edit'] ) // approval auth
            $approve = 1;
            if ( $cat_switch )
               update_kb_number( $old_category_id, ( $old_approve == 1 ? '- 1' : '0' ) );
               update_kb_number( $category_id, '+ 1' );
            $approve = 2;
            if ( $cat_switch )
            $approve = 1;
            if ( $cat_switch )
            $approve = 2;
            if ( $cat_switch )
Beitragvon AmigaLink » 3. Sep 2005 02:11
Und noch einer (von mir):
includes/function_kb.php
# in function get_kb_author();
      mx_message_die( GENERAL_ERROR, "Could not obtain author data", '', __LINE__, __FILE__, $sql );
      return ''; //mx_message_die( GENERAL_ERROR, "Could not obtain author data", '', __LINE__, __FILE__, $sql );
# in function get_kb_cat_list();
      mx_message_die( GENERAL_ERROR, "Could not obtain category information", '', __LINE__, __FILE__, $sql );
      return; //mx_message_die( GENERAL_ERROR, "Could not obtain category information", '', __LINE__, __FILE__, $sql );
Sicherheits Fix
Beitragvon AmigaLink » 18. Mai 2006 23:58
Und ein ganz wichtiger von dEfEndEr (der scheint momentan verschiedene MODs auf diese Schwachstelle zu prüfen 8) ):
includes/kb_constats.php
// ---------------------------------------------------------------------START
// This file defines specific constants for the module
if ( !defined('IN_PHPBB') )
   die("Hacking attempt");
Beitragvon AmigaLink » 5. Jan 2007 15:18
Noch ein kleiner Fix. Dieses mal von Billy Regal. :)
#-----[ OPEN ]-----
templates/subSilver/kb_footer.tpl
#-----[ FIND ]-----
<input type="submit" value="{L_QUICK_CAT}" class="liteoption" /></span>
<input type="submit" value="{L_QUICK_JUMP}" class="liteoption" /></span>
