break-tag to the announcements of the ezPortal
Beitragvon AmigaLink » 16. Okt 2005 21:00
## Mod Title:   Add a break-tag to the announcements of the ezPortal-Mod
## Mod Version:   0.2b
## Rev Date:   August, 14th, 2005
## Authors:   *Speedy* www.rwTools.de
## Description:   Adds a break-tag to the ezportal-news. Upon this tag a manual
##                break is executed, the news are stopped and the read-full is shown.
##        The [break] does not appear in read-full-mode, in the forum or as a button
##        next to the other bbcodes while posting
## Tested:      ezPortal
## Installation Level:   easy
## Installation Time:   1-5 Minutes
## Files To Edit:   3
##         portal.php
##         fetchposts.php
##         includes/bbcode.php
## Included Files:   no
## Security Disclaimer: This MOD Cannot Be Posted To Or Added At Any Non-Official phpBB Sites
## Author Notes:
##   Mich störte immer der feste Wert wo die News umgebrochen wurden. Befindet
##   sich darin ein BBcode Tag oder etwas anderes, wird dies dann im Klartext
##   angezeigt und zerstört die Darstellung. Um diesem Problem entgegen zu treten.
##   Setzte ich die Newslänge auf 0, was jedoch den Nachteil hatte, dass die Newsanzeige
##   ziemlich lang wurde.
## Before Modifing The ezPortal MOD In Your Forum, You Should Back Up All Files Related To This MOD
## Version History:
##   0.1 adding [break] tag to fetchposts.php
##   0.2 remove [break] tag in bbcode.php
##   0.2a updated install-text for standard ezPortal
##   0.2b made the install-text EM-compatible - no code changes whatsoever
## install.txt made by *Speedy*
portal.php
$fetchposts = phpbb_fetch_posts($CFG['news_forum'], $CFG['number_of_news'], $CFG['news_length']);
$fetchposts = phpbb_fetch_posts($CFG['news_forum'], $CFG['number_of_news'], $CFG['news_length'], 'true');
$fetchposts = phpbb_fetch_posts($CFG['news_forum'], $CFG['number_of_news'], 0);
$fetchposts = phpbb_fetch_posts($CFG['news_forum'], $CFG['number_of_news'], 0, 'false');
fetchposts.php
function phpbb_fetch_posts($forum_sql, $number_of_posts, $text_length)
function phpbb_fetch_posts($forum_sql, $number_of_posts, $text_length, $bol_break)
         stripslashes($posts[$i]['post_text']);
if (count(explode('[break]', $posts[$i]['post_text'])) == 2 && $bol_break == 'true'){
            $exp_news = explode('[break]', $posts[$i]['post_text']);
            $posts[$i]['post_text'] = $exp_news[0] . '...';
            $posts[$i]['post_text'] = bbencode_second_pass($posts[$i]['post_text'], $posts[$i]['bbcode_uid']);
            $posts[$i]['striped'] = 1;
         if (($text_length == 0) or (strlen($posts[$i]['post_text']) <= $text_length))
         elseif (($text_length == 0) or (strlen($posts[$i]['post_text']) <= $text_length))
includes/bbcode.php
$text = " " . $text;
$text = str_replace("[break]", "", $text);
// removing [break] tag in News
