[Bugfix] Translate posts 0.5.6
Beitragvon AmigaLink » 1. Nov 2005 16:32
Im Übersetzungsfenster des Translate posts MOD (0.5.6) von Niels erscheint nur die Fehlermeldung "Session not exists". Dieser kleine Fix behebt das Problem:
viewtopic_translate.php
$session_id = (isset($HTTP_GET_VARS['sid'])) ? $HTTP_GET_VARS['sid'] : '';
// $session_id = (isset($HTTP_GET_VARS['sid'])) ? $HTTP_GET_VARS['sid'] : '';
// Start special session management
$sql = "SELECT u.*,s.*
   FROM " . SESSIONS_TABLE . " s, ". USERS_TABLE . " u
   WHERE u.user_id = s.session_user_id
   AND s.session_id='$session_id'";
   message_die(GENERAL_ERROR, "Could not obtain post information", '', __LINE__, __FILE__, $sql);
if ( !($userdata = $db->sql_fetchrow($result)) )
   message_die(GENERAL_MESSAGE, 'session does not exist');
Beitragvon mariocaz » 3. Nov 2005 02:46
Thanx my dear friend :P , you're always awesome!!!! :wink:
Now it works! 8)
Regards,
Mario
Added after 20 minutes:
Mmmmmmmm :( :( :?
I saw an error when I do the translation in my forum. :cry:
This is the errors that appears: :idea:
I think that is because I have installed the Junior Admin MOD, can you take a look to this file ? :oops:
I am so sorry for that my friend, please help me. :oops:
Added after 1 days 8 hours 20 minutes:
:( :cry:
functions_jr_admin.zip
This is my file
(4.04 KiB) 1921-mal heruntergeladen
mariocaz
Beitragvon AmigaLink » 3. Nov 2005 13:49
Sorry but i don't know wath this can be. I think the error comes from the viewtopic_translate.php but i can't reconstruct what this file do with the functions_jt_admin.php. Because i don't use this MOD here on AmigaLink.de
Beitragvon pepi » 6. Nov 2005 20:01
also bei mir funktioniert der fix nicht
bekomme dann nur ne weisse seite
steht bei mir so drin
init_userprefs($userdata);
// End session management
gruß Pepi
pepi
Beitragvon mariocaz » 10. Nov 2005 01:30
Hello there!!! :D
Here are more fixes for this fine MOD:
http://www.net4seven.de/viewtopic.php?t ... fa3687f29c
Best Regards,
Mario :wink:
mariocaz
Beitragvon AmigaLink » 10. Nov 2005 19:50
@ pepi
Du hast meinen Fix ja auch nicht richtig drin!
@ mariocaz
THX
Beitragvon pepi » 10. Nov 2005 19:54
AmigaLink hat geschrieben:@ pepi
ne habe ich nicht denn wenn ich den reinschreibe habe
ich bei der übersetzung ne weisse seite ...........
habe dieses update gemacht jetzt funktioniert es
## MOD Title:  Update Fix for Translate posts / viewtopic.php
## MOD Author: easygo < webmaster@net4seven.de >
## MOD Description: Just a Babelfish fix to avoid some problems
##                  with translate_posts MOD by Niels Chr. Rød
## MOD Version: 1.07
## Installation Level: easy
## Installation Time:  1 minute
## Files To Edit: 1
##                viewtopic.php
## For security purposes, please check: http://www.net4seven.de/ for the
## to enter into your phpBB Forum. As such, phpBB will not offer support for MODs not offered
## in our MOD-Database, located at: http://www.phpbb.com/mods/downloads/
## Before adding this MOD to your forum, you should back up all files related to this MOD
#-----[ OPEN ]-------------------------------------------------------
viewtopic.php
$translate_link = '<a href="http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=' . $babelfish_lang_code[$translate_from] . '_' . $babelfish_lang_code[$translate_to] . '&url=' . urlencode($translate_url.$post_id.'&sid='.$userdata['session_id'].'#'.$post_id) . '" target="_blanc">';
#-----[ REPLACE WITH ]----------------------------------
$translate_link = '<a href="http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=' . $babelfish_lang_code[$translate_from] . '_' . $babelfish_lang_code[$translate_to] . '&trurl=' . urlencode($translate_url.$postrow[$i]['post_id'].'&sid='.$userdata['session_id']) . '" target="_blank">';
$translate_link .= '<a href="http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=' . $babelfish_lang_code[$translate_from2] . '_' . $babelfish_lang_code[$translate_to] . '&url=' . urlencode($translate_url.$post_id.'&sid='.$userdata['session_id'].'#'.$post_id) . '" target="_blanc">';
$translate_link .= '<a href="http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=' . $babelfish_lang_code[$translate_from2] . '_' . $babelfish_lang_code[$translate_to] . '&trurl=' . urlencode($translate_url.$postrow[$i]['post_id'].'&sid='.$userdata['session_id']) . '" target="_blank">';
#-----[ SAVE/CLOSE ALL FILES ]---------------------------------------
and THX mariocaz
gruß Pepi
pepi
Beitragvon AmigaLink » 10. Nov 2005 20:06
Wenn der Fix Funktioniert ist ja alles klar. ;)
Das du aber mit meinem eine weisse Seite erhälst ist unlogisch. Denn es wird lediglich eine (unnötige) Datenbankabfrage auskommentiert!
