wenn ich die neue includes/usercp_confirm.php verwende, funktioniert dieser mod leider nicht mehr:
- Code: Alles auswählen
## MOD Title: Visual Confirmation for Guests
## MOD Author: Kanuck < aaron@kanuck.net > (Aaron Adams) http://kanuck.net/
## MOD Description: Adds visual confirmation for guest posts, eliminating spam.
## MOD Version: 1.0.1
## Installation Level: Easy
## Installation Time: 3 Minutes
## Files To Edit: posting.php, templates/subSilver/posting_body.tpl
## Included Files: n/a
## Author Notes: None
## MOD History:
## 2005-02-18 - Version 1.0.1
## - It works now. No more parse errors.
posting.php
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
png visual confirmation system : (c) phpBB Group, 2003 : All Rights Reserved
case 'editpost':
case 'newtopic':
case 'reply':
if ( $board_config['enable_confirm'] && !$userdata['session_logged_in'] )
if ( empty($HTTP_POST_VARS['confirm_id']) || empty($HTTP_POST_VARS['confirm_code']) )
$error = TRUE;
$error_msg .= ( ( isset($error_msg) ) ? '<br />' : '' ) . $lang['Confirm_code_wrong'];
$confirm_id = htmlspecialchars($HTTP_POST_VARS['confirm_id']);
if (!preg_match('/^[A-Za-z0-9]+$/', $confirm_id))
$confirm_id = '';
$sql = 'SELECT code
FROM ' . CONFIRM_TABLE . "
WHERE confirm_id = '$confirm_id'
AND session_id = '" . $userdata['session_id'] . "'";
message_die(GENERAL_ERROR, 'Could not obtain confirmation code', __LINE__, __FILE__, $sql);
if ($row['code'] != $HTTP_POST_VARS['confirm_code'])
$error = TRUE;
$sql = 'DELETE FROM ' . CONFIRM_TABLE . "
if (!$db->sql_query($sql))
message_die(GENERAL_ERROR, 'Could not delete confirmation code', __LINE__, __FILE__, $sql);
$error = TRUE;
$db->sql_freeresult($result);
// Generate smilies listing for page output
generate_smilies('inline', PAGE_POSTING);
// Visual confirmation for guests
$confirm_image = '';
if( !$userdata['session_logged_in'] && (!empty($board_config['enable_confirm'])) )
$sql = 'SELECT session_id
FROM ' . SESSIONS_TABLE;
$confirm_sql = '';
do
$confirm_chars = array('A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', '1', '2', '3', '4', '5', '6', '7', '8', '9');
mt_srand($sec * $usec);
$code = '';
for ($i = 0; $i < 6; $i++)
unset($code);
$confirm_image = (@extension_loaded('zlib')) ? '<img src="' . append_sid("profile.$phpEx?mode=confirm&id=$confirm_id") . '" alt="" title="" />' : '<img src="' . append_sid("profile.$phpEx?mode=confirm&id=$confirm_id&c=1") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&id=$confirm_id&c=2") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&id=$confirm_id&c=3") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&id=$confirm_id&c=4") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&id=$confirm_id&c=5") . '" alt="" title="" /><img src="' . append_sid("profile.$phpEx?mode=confirm&id=$confirm_id&c=6") . '" alt="" title="" />';
$hidden_form_fields .= '<input type="hidden" name="confirm_id" value="' . $confirm_id . '" />';
'SMILIES_STATUS' => $smilies_status,
'CONFIRM_IMG' => $confirm_image,
'L_DELETE_POST' => $lang['Delete_post'],
'L_CONFIRM_CODE_IMPAIRED' => sprintf($lang['Confirm_code_impaired'], '<a href="mailto:' . $board_config['board_email'] . '">', '</a>'),
'L_CONFIRM_CODE' => $lang['Confirm_code'],
'L_CONFIRM_CODE_EXPLAIN' => $lang['Confirm_code_explain'],
{POLLBOX}
<!-- Visual Confirmation -->
<!-- BEGIN switch_confirm -->
<td class="row1" colspan="2" align="center"><span class="gensmall">{L_CONFIRM_CODE_IMPAIRED}</span><br /><br />{CONFIRM_IMG}<br /><br /></td>
<td class="row1"><span class="gen">{L_CONFIRM_CODE}: * </span><br /><span class="gensmall">{L_CONFIRM_CODE_EXPLAIN}</span></td>
<td class="row2"><input type="text" class="post" style="width: 200px" name="confirm_code" size="6" maxlength="6" value="" /></td>
<!-- END switch_confirm -->
hast du eine idee was ich daran ändern muss um hier auch die advanced version nutzen zu können?
