make it non case sensitive.
Beitragvon Maximiliam » 4. Feb 2007 12:42
Hello,
How do you make it non case sensitive? I think the worst problem for our users is that you have to enter the word with big and small letters. Is there a way to make it so it is not case sensitive? So BIG and small letters does not matter?
/Maximiliam
Maximiliam
Beitragvon AmigaLink » 5. Feb 2007 13:00
if ($row['code'] != $confirm_code)
if ($row['code'] != strtoupper($confirm_code))
Thus you reduce the security of the CAPTCHA.
Beitragvon Maximiliam » 5. Feb 2007 19:34
The file that you make the change in is includes/usercp_register.php for anyone that wonders.
It works great, thanks :)
Maximiliam
Mitglieder in diesem Forum: 0 Mitglieder und 38 Gäste
